It is currently Thu Aug 21, 2025 6:46 am
PostPosted: Sun Mar 23, 2014 6:35 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I was thicknessing a cocobolo back today and the joint separated on one side of the sandwiched backstrip about half the way. I glued with LMI white glue after wiping with acetone. This was the recommendation on LMI's website and I have since read several threads about the acetone actually bringing more oil to the surface. The back is sanded to about .095". What should I do?
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sun Mar 23, 2014 6:57 pm
State: Tennessee
Bummer
I like to go from the shooting board to glue that sucker up. I use hhg exclusively, don't know anything about LMI white.
PostPosted: Sun Mar 23, 2014 7:03 pm
Press it back together and use CA ... in future, don't wipe .. unless you want to keep wiping until no more colour comes out, you have to get rid of all the resins the acetone is leaching out ... me, I don't bother, I just plane the joint, and then use fish glue
PostPosted: Sun Mar 23, 2014 7:07 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
same as above , but used titebond , 319 hhg , or fish
PostPosted: Mon Mar 24, 2014 7:54 am
City: Tyler
Make sure the coco is fully acclimated to your shop. I only had a separation on wood that I had not held long enough. I have had no problems with coco seam separation on wood that I have had stored for several months or years before using.
